  1. I have downloaded a Divx movie with XNap (Ntsc - 640x480 at 23.976 fps) and I would convert it on CVD format.
    If I mantain the Ntsc settings (352x480 - 23.976 fps) on Video Parameters no problems, but If I try to convert it in PAL (settings: 352x576 - 25 fps) audio and video get out of sync.
    QT Decode option is flagged...
    I may be wrong but seems that FFMPEG encodes on 25 frames per seconds only the video track (and the audio parts remains at 23.976)!!!
    Anyone has a solution? Thanks.
  2. Originally Posted by SIMPLE_THINGS
    Do you have the Quicktime MPEG-2 Decoder installed?
  3. Originally Posted by SCB
    Yes (I usually watch my Divx/Mpeg2 with QT...)
  4. Put the DivX in a MOV container with DivX Doctor II and encode the .mov
  5. Originally Posted by major
    Sorry but FFMPEG goes on crash after few minutes of encoding...
    Tryed 3 times with 3 different Divx (converted by Divx Doctor II).
  6. Post terminal output..
  7. Originally Posted by major
    Here I am!
    The console log says:
    Date/Time: 2003-01-17 18:25:01 +0100
    OS Version: 10.2.3 (Build 6G30)
    Host: G4MP.local.
    Command: movtoy4m
    PID: 594
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_INVALID_ADDRESS (0x0001) at 0x02763000
    Thread 0 Crashed:
    #0 0x01684ad0 in 0x1684ad0
    #1 0x016842c8 in 0x16842c8
    #2 0x01677460 in 0x1677460
    #3 0x90222d88 in CallComponentFunctionCommon
    #4 0x90236b70 in CallComponentFunctionWithStorageProcInfo_TVector
    #5 0x01236620 in 0x1236620
    #6 0x01677ad8 in 0x1677ad8
    #7 0x9202e7cc in ImageCodecDrawBand
    #8 0x89f35a18 in BaseCodec_DecompressWorkFunction
    #9 0x89f35e1c in BaseCodec_DecompressCallBack
    #10 0x89f3621c in Base_CDBandDecompress
    #11 0x90222d88 in CallComponentFunctionCommon
    #12 0x89f36928 in Base_CDComponentDispatch
    #13 0x01677b04 in 0x1677b04
    #14 0x9202db88 in ImageCodecBandDecompress
    #15 0x91f886a8 in QuadToQuadMatrix
    #16 0x91f8f404 in ICMSetSequenceOverdrawnCallback
    #17 0x91f8ed68 in ICMSetSequenceOverdrawnCallback
    #18 0x91f73fd0 in DecompressSequenceFrameWhen
    #19 0x89e94c14 in rDecompressSequenceFrameWhen
    #20 0x89e9450c in decompressVideoFrame
    #21 0x89e8d140 in VideoMoviesTask
    #22 0x90222de8 in CallComponentFunctionCommon
    #23 0x89e8ad98 in VideoComponentDispatch
    #24 0x9202f998 in MediaMoviesTask
    #25 0x91fb4ae0 in MakeHandleRoom
    #26 0x91fb3dec in MakeHandleRoom
    #27 0x00006da4 in -[VideoOutput convert]
    #28 0x00004ff0 in main
    #29 0x00004524 in _start (crt.c:267)
    #30 0x000043a4 in start
    Thread 1:
    #0 0x90073c48 in mach_msg_trap
    #1 0x90005f90 in mach_msg
    #2 0x90148b10 in __CFRunLoopRun
    #3 0x90180fe4 in CFRunLoopRunSpecific
    #4 0x94d9c1c0 in _ZN10HALRunLoop9OwnThreadEPv
    #5 0x94d911b0 in _ZN9CAPThread5EntryEPS_
    #6 0x90020d48 in _pthread_body
    PPC Thread State:
    srr0: 0x01684ad0 srr1: 0x0200d030 vrsave: 0x00000000
    xer: 0x20000000 lr: 0x01683230 ctr: 0x01684750 mq: 0x00000000
    r0: 0x008000cf r1: 0xbfffe520 r2: 0x0101f000 r3: 0x01d9aea0
    r4: 0x02762fff r5: 0x00000020 r6: 0x018eea88 r7: 0x00000150
    r8: 0xbfffe664 r9: 0x00000280 r10: 0x000001e0 r11: 0x01759000
    r12: 0x010177b0 r13: 0x00000000 r14: 0x002156a0 r15: 0x00000000
    r16: 0x24428282 r17: 0x00000000 r18: 0x44428282 r19: 0x015b5590
    r20: 0x0275f027 r21: 0x00003fd4 r22: 0xbfffe664 r23: 0x00000280
    r24: 0x00000001 r25: 0x00000000 r26: 0x01d9aea0 r27: 0x01739000
    r28: 0x01078000 r29: 0x00000001 r30: 0x00000000 r31: 0x01759000
