I have LORD OF THE RINGS 1 extended version on dvd and i want to convert it to svcd. But the movie is on 2 dvd's. 1 dvd doesnt fit on 1 svcd but on 2. As i dont want to get 4 svcd's i want to be able to make 3 svcd's of those 2 dvd's. IS that possible?
Results 1 to 10 of 10
it will fit fine, dont worry. but how do i do something like this? cant rip from 2 dvd at once (i use dvd2svcd)
rip all the vobs to your hard drive first (rename second disk vobs as a continuation of first disk and then put in same folder) , then you have a couple choices..
you can make a new ifo files with ifoedit and then use dvd2svcd would prob be the fastest
you could skip dvd2svcd and do it all manually
someone may have a better idea
also - what is wrong with 4 cd's ? or disk 1 on 2cd and disk 2 on 1cd ? -
havent thought of that last option yet.... maybe thats possible. have to see that. thanks atleast
disk2 on 1 cdOriginally Posted by BJ_M
disk two is almost two hours so that too would be 2 cds
1 hour for each svcd is very decent quality on 2 pass vbr for anamorphic widescreen. try what BJ_M suggested it should turn out good. I'm just about to do LOTR extended but I'm doing 4 xsvcd's
Total running time is actually 3.5 hours.Originally Posted by Jonathan Archer
might be hard to link the vobs from first disc to next disc...
at least with me, linking made the audio from the second dvd disc outta sync...with LOTR extended
i never had this problem with other movies that required linking of the vobs from different DVDs..(i.e. stargate, godfather 2, goodfellas)
btw, prolly good idea to make the movie into 4 discs...as the extended version is 3.5 hours long
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
HDTV makes DVD movie look "less" like a movie?
By breakchange in forum DVB / IPTVReplies: 73Last Post: 6th Oct 2011, 10:28 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 11:10 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33
