I use womble and it works perfectly... But, i am teaching my mom how to cut the home videos and there are a few things that womble is bad for. That leads to my mom making a bunch of mistakes.
1) No DVD preset and depending on how you open the video file to edit it sometimes defaults to having video settings from the file or sometimes it defaults to SVCD settings.
2) Don't like how it needs a seperate file to be saved for the batch processing. Or at least suggest a batch file name with the same name as the video file that will be output. Ideally, not having to save a file.
3) Once you start a batch process you can't pause it. Nor do you know which file it's processing... Just the precentage of the current file.
4) Doesn't remove items from the queue after completion.
I've heard some other editors like M2-edit and some other programs i can't remember.
Is there a program that is easier to use for cutting MPEG2 files at 720x480 with a bitrate of about 6000000. That i could have my mom use.
Thanks in advance
Results 1 to 1 of 1
VOB2MPG Batch Processing
By jonj1611 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 26th Aug 2011, 13:35 -
Batch Processing
By keefytee in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 7th May 2011, 04:41 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 00:00 -
Batch processing .AVI
By R2 in forum Newbie / General discussionsReplies: 2Last Post: 12th Feb 2008, 20:34 -
Batch Processing
By ruggie_uk in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 19th Jul 2007, 06:04
