I used to capture my avi's at 640x480 as yuv2 uncompressed (and sometimes 480x480) with VirtualVCR. I started to use Huffyuv compression arround Christmas time (640x480 and 480x480) due to the recommendation of the author of VirtualVCR (excellent program). These avi's were then edited in VirtualDub (commercials removed) and frameserved to Tmpgenc 2.51 Plus and encoded as a SVCD or CVD.
However I just noticed that my avi's that were captured as uncompressed resulted in a much better SVCD or CVD (picture quality and sharpness) then those avi's I captured using Huffyuv YET I was under the impression that Huffyuv was a lossless compression ?
Anything I maybe overlooking ?
Interesting... I would like to know too.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
No, but I would like to know if "Huffyuv" is realy lossless compresion and if "yuv2 uncompressed" is better ? I saw a lot that Huffyuv is recomended.
I just captured tonites Star Trek Voyager in uncompressed avi (480x480) YUV2 and it is much sharper then when I use Huffyuv with settings YUV2 compression method->predict median (best) & RGB compression method->Predict gradient (best)....
The encoded CVD was much better then the one created from an avi using Huffyuv 2.1.1.....why would this be ?
The CVD template used was the one here in the Tools section.
Cheers
huffyuv help
By liquidr0x in forum Video ConversionReplies: 31Last Post: 18th Feb 2015, 06:31 -
How do I install Huffyuv (mt)?
By blud in forum Newbie / General discussionsReplies: 8Last Post: 6th Apr 2012, 06:47 -
H.264 to HuffYUV
By PuzZLeR in forum Video ConversionReplies: 13Last Post: 4th Apr 2008, 00:25 -
is it possible to compress HUFFYUV?
By Lee82 in forum Newbie / General discussionsReplies: 3Last Post: 10th Aug 2007, 12:56 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 09:55
