  1. Can I rip the DVD movie special features like "Movie in the Making" using SmartRipper?
    Any help is appreciated.
    Feb 2001
    Berlin, Germany
    Sure, you only need to know, which .vobs contain the special features, that you want. You are on the safe side, when you switch the rip method from "movie" to "files" and select all files. Then use a dvd software player to look, what is what.
    May 2001
    Somerset, CA
    I usually play the DVD first to see what extras are on the disc & how long each "part" is. In Smart Ripper (file mode) you can then (just like using Windows Explorer) click on the + to get to the other files you want to rip. Since Smart Ripper also shows the actual play time you know pretty much ahead of time what you're going to be ripping.
