okay i wanna take some audio from a vcd i have. i was playing it in windows media and trying to record from the sound card using a program called total recorder. it looks like it records fine and plays like the first 40 seconds and then it gets all screwed up and doesnt play right. is there another program i can use?
You can use tmpgenc's MPEG Tools to demultiplex the audio stream from the VCD MPEG to an MP2 file, which you can then play or convert.
an easier way is 2 grab urself a program called MultiQuence...then in the 'Track' menu select > add Audio Section...then from the 'File' menu select > Save Wave As...there u have it, u can take the WHOLE track or just a selection from it...
VdubOriginally Posted by djcrump
File > Open Video (*.*) > VCD > .dat
Audio > Direct stream copy
SAVE WAV
A better edeting program, and one of the first ever is www.goldwave.com
See also
http://www.vcdhelp.com/forum/userguides/137413.php
Works with Mpeg 1 also
Extracting audio from flv
By Mike99 in forum AudioReplies: 30Last Post: 22nd Apr 2011, 09:31 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 17:22 -
Extracting Music from Audio CD
By prayami in forum AudioReplies: 4Last Post: 4th Aug 2008, 18:59 -
extracting audio and changing it
By usermm in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2008, 15:41 -
Extracting audio with VirtualDub
By RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 20:03
