I have the Verbatim DVD+RW writer M#VBTDVRW1A. I can burn with most any program to DVD+R but, nothing will work with DVD+RW. Using verbatim media with it.
Please give us more detail of what is the DVD writer you use and what do you burn and what player you use to play the burned dvd and what software you use to burn the dvd.
try using the free bitsetter at dvdplusew.org and change your +RW to read as a DVD-Rom see if that helps.
Q-Please give us more detail of what is the DVD writer
A-I have the Verbatim DVD+RW writer M#VBTDVRW1A.
Q-what do you burn.
A-DVD backups
Q-what player you use to play the burned dvd
A-Sony, plays DVD+R\RW, VCD,SVCD,DVD.MP3,CD
Q-software you use to burn the dvd.
A-Nero, Nero express.
Only way to write is with MYDVD.
Can't even erase with nero "SCSI target error" -
Originally Posted by Marco33
When I saw Verbatim DVD+RW I skipped word "writer" too
Confusing
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
What is the exact problem? An error during the recording or only a playback problem? If it's the first case then try a different burning software. If it's a playback problem check that your DVD player really support DVD+RW (but most Sony players do that so it should not be the problem, see here).
Your Verbatim drive is not really a Verbatim, it's either a Ricoh 5125 or a NEC ND-1000A (you can check which one it is in your burning software or with Nero Infotool). The bitset util only works with Ricoh drives but it only fixes the problem where the DVD player does not recognize the DVD+RW book type.
Verbatim DVD-RW
By Jestak in forum DVD RippingReplies: 7Last Post: 11th Jun 2010, 11:27 -
verbatim DVD
By avextraxjp in forum Newbie / General discussionsReplies: 4Last Post: 7th Mar 2009, 21:08 -
Verbatim DVD+R DL Disks?
By albloom in forum MacReplies: 12Last Post: 21st Oct 2008, 10:52 -
Verbatim DVD-R/+R @ Officemax
By DVD-BLUES in forum MediaReplies: 0Last Post: 6th Sep 2007, 14:00 -
Verbatim glossy DVD-R?
By spiffy in forum MediaReplies: 1Last Post: 28th Jun 2007, 12:51
