what can i do to make this player play the vcd's i make on my computer. This thing won't play anything. I also had a apex 1500 and it wouldn't play vcd's either so i took it bake but cant take the 500 back please help
I suggest you read the user comments and reports for your particular version (there are multiple versions) of the AD-500 at:
http://www.vcdhelp.com/dvdplayers.php?DVDname=apex+ad-500&Submit=Search&Search=Search
The "comments" will probably tell you what needs to be done. At the very least you should probably try burning to CD-RW disks. Some DVD players have known problems with CD-R disks.
USB 500 capture
By kortmann in forum Capturing and VCRReplies: 2Last Post: 18th Sep 2010, 19:44 -
What's a good tv for $500
By fairytale00 in forum DVB / IPTVReplies: 8Last Post: 21st Aug 2010, 18:21 -
Best camcorder for around $500
By Hank Kinsley in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Feb 2009, 04:15 -
VC 500
By jlh050965 in forum Capturing and VCRReplies: 1Last Post: 24th Sep 2008, 11:00 -
Help with Hauppauge PVR 500.
By seymoria in forum Capturing and VCRReplies: 0Last Post: 24th Jul 2008, 05:27
