Hi guys,
I just made a DVD-SVCD for my Philips 952. Everything worked fine after following this guide: http://www.vcdhelp.com/svcddvdr.htm
I also followed som other guidelines as to do selectable subs on SVCD which I have done sucessfully with regular SVCD's on the same player. But when doing this DVD-SVCD the subs didn't show up and was not selectable in the player menu. I am sure I did it right as for following the SVCD standard but it just didn't work this way.
Does anyone know if its possible or does the fact that I fool the player into believing its a DVD is playing disable my SVCD subs?
Is there any other way I can make it work?
regards
Kris
Results 1 to 9 of 9
I just discovered that burning a classic SCVC with subs in Uleads program doesn't work at all so I am inclined to guess that it is the program who isn't fully compliant.
I am going to try the whole process using WinOnCd 6 DVD.Edition and see what comes out of it. WinOnCd works with subtitles.
Let you all know soon
Kris -
You can have subs on a DVD and subs on a SVCD. But you can't just 'turn' SVCD subs into DVD subs. They have to be ripped and converted first.
http://www.doom9.org/subtitle_guides.htm
Has some good guides on the subject. -
Hmm, I realize that WinOnCd won't work either since when you load up all the assets and hit "burn". The program starts to de-multiplex and multiplex which will make the subtitles go away.
I still want to do the header hacked DVD-SVCD but in what way can I make "DVD-subtitles" to put in and along the rest of the files. In Ulead I can get an output of all the filework which results in these files and folders:
AUDIO_TS
*empty
VIDEO_TS
VIDEO_TS.BUP
VIDEO_TS.IFO
VIDEO_TS.VOB
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_1.VOB <---- The first MPEG2
VTS_01_2.VOB <---- The second MPEG2
VTS_01_3.VOB <---- The third MPEG2
VTS_01_4.VOB <---- The fourth MPEG2
I realize it aint as simple as to just drop in "subtitle.vob" but I wish it was. How can I make this easier for myself? I have DVD Maestro but I don't really know how it works.
Kris -
Here's a Maestro guide:
http://www.doom9.org/mpg/maestro.htm
Maestro is pretty easy to use. As for getting the subs into a usable format that can be a little more tricky. Look at the subtitle guides at doom9.org (see link above). -
Can you use the Svcd header trick with DVD Maestro, and does it support Mpeg audio?
Well yes and no I guess. The header trick works as for importing the movies, Maestro scans it and finds it to be ok - but when I try to mount it on the timeline the program crasches. This could just be my computer perhaps but I am inclined to think that this is a common "bug".
As for mpeg audio I think it's ok, but I am going out on a limb here.
Kris -
Have you been able to rip the subtitles from the SVCD? If not you can not make any dvd with subtitles.
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 07:15 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28
