  1. can i capture a DV on frame 352x288 ?
  2. what do u mean about ? is it render first to make 352x288 or just capture it ? i think that PAL DV is 720x576 frame. i work on PAL system.
  3. I put question marks next to sure because I (and probably no one else on this forum) had any idea what you were asking. Since I have no idea what you are trying to do with the film, your second question:
    "is it render first to make 352x288 or just capture it ? i think that PAL DV is 720x576 frame. i work on PAL system."
    I would answer the same way, soure, you can do either. I am not trying to sound like a smart ass here, but I have no idea what you are trying to do with the file after you (I assume) pull it into your computer?
    Can you tell me exactly what you are trying to do and why? [/quote]
  4. well if its vdub ur using, in capture mode goto video --> set custom format and u can capture at any of the formats they have, but capture at too high a format like 720 X 576 I've noticed that you drop a lot of frames.
