Results 1 to 9 of 9
  1. i tried to convret a m2v to mpeg using tmpgenc but it says 4 s packets cause buffer underflow. what does that mean? and how can i fix it? or is there another software that wont give me this problem?
    Mar 2002
    United States of America
    If you re-multiplex with bbMPEG, you won't get any buffer over/underflow errors at all. It's in the Tools Section.
    Hope That Helps!!! :P
  3. how do i open a m2v file using bbMPEG?
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    he not talking about multiplexing buffer problems but VBV buffer problems and most likly it is a problem with the source files ..
    bbmpeg will not help you ..
  5. BJ_M i was doing a simple multiplexing, in file and mpeg tools. thats where theproblem occured
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    oh -- you said converting first , not multiplexing ..
    yes - try bbmpeg for that ... there is a guide for it here
  7. sorry i meant multiplexing when i said converting. can tmpgenc convert? i thought that was the only way to make it to mpeg 1
  8. i tried to add the m2v file on bbmpeg, but it keeps bringing up some error. i cant read the error because it goes away really fast
  9. anyone have any ideas whats going wrong?
