Another newbie needing help. I've been using VCDEasy ver. 1.1.3 to burn my vcd's and importing my chapter info from Chapter Tractor. Now lately VCDeasy won't burn the chapters after a successful import. When I test it using PowerDVD XP it just jumps to the end of the disk. Any settings I should recheck? I mainly use default settings for VCDEasy.![]()
If it works, don't mess with it, don't tinker with it and don't break it.
Make sure you have PBC enabled when creating chapters because if you don't, when you press >>| the movie will skip to the end instead of to the chapter.
Thanks, I'll recheck that. I went and did a reinstall to a different location instead of the default it tries to do. It wants to install by default to my C drive, but that's my 98se drive on a dual boot setup.
missing chapters on standalone dvd
By lukasz.w80 in forum Authoring (DVD)Replies: 7Last Post: 10th May 2011, 16:38 -
missing chapters on standalone dvd - dvdlab
By lukasz.w80 in forum Authoring (DVD)Replies: 0Last Post: 10th May 2011, 09:56 -
chapters points missing from .MKV trimmed with AVIdemux
By DaveIsHere in forum Video ConversionReplies: 2Last Post: 22nd Aug 2010, 17:40 -
Chapters missing or out of sequence when converting VIDEO_TS to .AVI or MPE
By Sloani in forum ffmpegX general discussionReplies: 2Last Post: 7th Mar 2010, 10:45 -
Missing a codec?
By jnojr in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2008, 17:24
