Hi,
There was this "Open DVD" in "File" menu in FlaskMPEG 0.594 version,
which can open the whole DVD in one shot for converting it into MPEG1/2.
This option seems to be missing in the new version, FlaskMPEG 0.6.
Anybody know how to open an entire DVD (after ripping it with
SmartRipper) in FlaskMPEG 0.6.
Thanks.
1st .6 isn't the latest there's a .7x available from sourceforge but I suggest Xmpeg 4.5 as a replacement. Anyway you have to have the right plugin with the right extension in the right folder.
see: http://www.divx-digest.com/articles/flaskmpeg6_setup.html -
fingernailX,
Appreciate your help.
Thanks for the info. I'll give xmpeg a try.
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 21:39 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
For those who face the "windows media player cannot open this file" problem
By sanosuke in forum Software PlayingReplies: 0Last Post: 1st May 2011, 08:00 -
GSpot says "File missing" but it is clearly visible in Explorer window?
By Iceblade in forum Software PlayingReplies: 9Last Post: 30th Mar 2010, 08:41 -
DVD Architect 4.5 missing "Insert: Submenu from file"
By sir_rob in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 11:39
