I had a large XVid AVI, which I successfully converted to MPEG2, using TMPGenc. I can view the MPeg, beginning to end, with good quality, in-sync sound.
I want to burn this to a DVD-R, so I run the mpeg through SpruceUp, to create the video_ts folder. At the end (98% or 99% complete) of the export, Spruce gives me a video error. Is there any other tool I can use or should be using, to create a burnable DVD file?
thanks
My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
2x512 MB DDR 500 ram
WinXP Pro
ATI Radeon X800pro
5x120 GB Western Digital ata100
TDK Velocd 48x16x44
Sony 8x DVD burner -
1) Did you demux the MPEG file into an M2V (video) and MPA (audio) file.
2) What's the resoultion of the video? 720x480, 352x480 and 352x240 are the only DVD legal resolutions. The default SVCD resolution of 480x480 is NOT supported. -
Thank you for the reply.
I did not demux the file. I had previously worked with the audio, while it was still an AVI. TMPGenc picked up the video and audio files and turned it into a working MPEG.
I'm not sure about the resolution, but if the resolution was unsupported, would Spruce not crash much earlier in the process, instead of at 99%.
I read somewhere else that this could sometimes be fixed by removing a few frames at the end. How would I do that?My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Update:
I cut 10 seconds off the front and 10 seconds off the back and re-ran Spruce. This time, it completed successfully.
My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Sony 8x DVD burner
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10 -
divx to mpeg2 with winff = error
By tors10 in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 15:58 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 11:03 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 2nd Aug 2007, 00:41
