I have a monster inc movie from europe and it has about 5 versions in diffrent languages and I want to rip and convert it to svcd but I only want to get the other language not the original english, I can rip the original movie with english without any problems but when I select the other language and deselect english I get no sound how do I do this, I use smart ripper 2.41 if anyone can help me I would be greatful, thanx ....
Use dvd2avi to extract the different audio tracks. english is usually track 1 so select the others and see which one is the one you need.
thanx it worked, I didnt think of changing the track number in dvd2avi thanx a lot
Hi shagrath,
I ripped a dvd,returned the dvd to the rental place, then found it in the wrong language. I used VOBRator. It worked for me. for some info:
http://www.doom9.org/index.html?/mpg/analyzeDVDcontent.htm
Steve -
I normally just use Smartripper or DVD Decrytper to rip the DVD w/ 'enable streaming processes' then select to demux the audio track I want.
This will generate an *.ac3 file with the language you want (and the m2v video if you select that as well).
Rip chapter in every language in every title
By kentmgf in forum DVD RippingReplies: 2Last Post: 23rd Sep 2011, 11:22 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
Making a dvd with an english track from a mkv file that has both japanese and english
By andyjc in forum MacReplies: 0Last Post: 12th Feb 2010, 09:41 -
How Panasonic DMR-E80H convert japanese to english Language
By tanveerriaz in forum DVD & Blu-ray RecordersReplies: 0Last Post: 9th Feb 2010, 07:30 -
re-author DVD adding a new subtitle language?
By u2paddy in forum Authoring (DVD)Replies: 2Last Post: 19th Apr 2008, 18:05
