Quick question: why does everyone seem to use tmpgenc? Is it really that much better than everything else, or just because it's free?
If I'm using PowerDirector (or any other package) for editing, and it also has the ability to encode to mpg2, is there a reason not to just do it with PowerDirector?
Is it a quality issue, and is tmpgenc really that much better?
Thanks.
Results 1 to 10 of 10
that's why:
http://www.vcdhelp.com/comparison.htm#mpegWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
It really is better (when used properly) than most other encoders, apart from CCE. And it is probably better than CCE for mpeg1. Certainly, if you compare it with Nero, Pinnacle or Roxio (and probably a lot of other pricier offerings) there is no comparison.
And TMPG is not free for mpeg2, but it is probably the best value software you can find anywhere. -
I can honestly say that I've never used a piece of software more than Tmpeg. For $49 it can do everything the big boys can (CCE etc) with the same quality at about 5% the cost.
Originally Posted by LanceSteel
You must have got a slightly imperfect version. Don't complain if it doesn't work properly. 8)
The simple rule of thumb is...
MPEG1/VCD, go for Tmpgenc.
MPEG2/SVCD, go for CCE.
Although I would really like to see a 4 pass Tmpgenc encoding, when its implemented... -
Originally Posted by Dodzzz
Originally Posted by tempe
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
