I have spent hours (okay days) trying to convert and burn an .avi file.
I encoded the avi file using Vdub to split the audio and TMPGenc to encode in 4 parts. Each part is 20 minutes. I can play each part of the encoded MPEG2 file on the PC and the quality and sound are perfect. It is encoded at 6000 fps.
I burned the DVD-R using UleadMF on Memorex DVD-R media. Prior to burning I previewed it using UleadMF and it looked great. Each of the 4 parts = a single chapter. Part 4, the video and audio in perfect sync.
Once burned using my Sony DRU500a, I played it in my JVC S502. It plays great (a little jerkiness but not that noticeable). The problem is that if I click on the menu and play chapter 4, the audio is off from the video by 5 seconds or more.
It must be something wrong with UleadMF or the Sony drive. Any ideas?
Thanks in advance for any suggestions.
Does Moviefactory reconverts the video and audio?? When you author and burn with moviefactoyr it should only multiplex if you have made the mpg with tmpgenc.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
