  1. hi..i have an anime dvd that has two movies on it...what i want to know if it is possible to rip out the 2nd movie with the english subtitles and then burn this to a dvd with the subtitles..all i want is the 2nd movie i dont want menues and other stuff just the movie and the subtitles..is this possible to do,,please help
    (posted this in the wrong section before sorry )
    Dec 2002
    Belgium
    With Smartripper and DVD Decrypter you can easily select which video, which audio and which subtitle streams you want to rip.
    But, pay attention to the Direct Stream Copy and Demux settings.
    You'll also need to rewrite the ifo files.
    cheerio,
    MrSnake
  3. http://www.vcdhelp.com/forum/viewtopic.php?t=109346
    Scroll down and look for 'EnemyWithin's post on how to use IFO edit.
    1) Rip whole movie to HD
    2) Run IFOEdit and find the PCG (program chain) with the moive you want
    3) Click 'VOB Extras'
    4) Select the language and subs you want to keep
    5) Click 'get VTS'
    6) Burn new VTS/VOB files
    This is MUCH easier than trying to de-mux/re-mux and author (esp for subtitles which would require ripping the subs and adding them back in). It's all in the guide and pretty simple. Another good guide for the same process can be found at:
    http://www.doom9.org/mpg/ifoedit-menustripping.htm
