is it possible to have multiple subtitles appear on a svcd after ripping for dvd
You can have up to 4 selectable S-VCD subtitles if your DVD-Player supports them. Prefer CVD to S-VCD subs, but you should test your player for compatibility yourself.
This is what I was finding all this time. Will subtitle be view with vcd too or is it only aviable for svcd only?
Only SVCDs support selectable (soft encoded) subtitles.
With VCDs you are limited to hard encoded subs, which are physically encoded into the picture so you cannot turn them off and on, and you can't switch between subtitle tracks. -
which software will rip both the subtitle and the movie at onces instead of DVD2VCD. Because DVD2VCD is sucks. It cuts too much movie out. (skip too much movie)
I don't know of any other program which can do it. I do it by hand, using subrip to rip the subs and WinSubMux to add them into the mpg stream. It only takes about 10 mins to add them in once the mpg is finished.
I know that many people use DVD2SVCD with great results. Personally, I prefer the control of doing everything manually, but if you are looking for an all-in-one solution than you cannot beat DVD2SVCD. Maybe you should give it another try. -
I understand that thats the best software, but it cuts a half of the movie off. This had happens to me many of time. What should I do to tell the dvd2vcd not to cut?
VOB2MPG PRO: Multiple Audios & Subs?
By kwanbis in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Jul 2011, 19:59 -
URGENT: Need to output to ASP DivX w/ Multiple Subs, Audio Tracks, Chapters
By Jeet in forum Authoring (DVD)Replies: 0Last Post: 7th Oct 2010, 17:14 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 08:55 -
Multiple SUBs on AVI file?
By poumtatalia in forum SubtitleReplies: 1Last Post: 6th May 2010, 04:15 -
Multiple Divx/Xvid files on DVD w/ menus and selectable subs?
By louv68 in forum DVD RippingReplies: 4Last Post: 18th Jul 2007, 09:01
