Hey guys, I have a question that hopefully has a very simple answer!!
Is there a very simple way or maybe even a program that I can use to capture a screenshot from a normal mpeg or media file?? I just want to be able to make some thumbnails of a mpeg.
Any help would be truly appreciated.
Thanks in advance guys![]()
You can use virtualdub.
Open your video file, then on the timeline use the mark in and mark out buttons to select a portion of the video file. This selection can be 1 frame or as many frames as you like. Then select file, save image sequence. Vdub will create a bmp file of each frame selected. -
Awesome job Craig!!! Thankyou very much for the info!!
I did try using Power DVD to capture a few still but it wouldn't work for some reason. But virtualdub should do the trick. Thanks again
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
