hi
I've backed up my copy of the fellowship of the Ring extended edition
(Region 2 PAL)
to VCD and there is a bizzare play back issue.
the DVD was ripped with DVD DeCrypter
Framserved from AVISynth the the Panasonic Mpeg 1 encoder v 2.30.
Aspect ratio was set to 16:9
Sound was encoded seperately with BSeweet.
The encoder encodes the video no problem.
Then the sound was multiplexed with the video using TMPEGEnc.
At this point all is well.
Playback of the muxed file on the PC is great with no sync issues or
glitches.
The file was then burned with nero as a compliant PAL VCD.
No reported errors from Nero.
Then the acid test play back on my Alba 103 standalone.....
Not good...The picture is shifted to the left half of the screen and flickers
like crazy.Audio playback is fine.
So try the same freshly burnt disc in my Bush 2004....plays fine, although
the picture is shifted to the left ever so slightly.
So any ideas on what's causing the severe playback probs on the Alba?
I have backed up many DVD's using the above method which play
perfectly on the Alba and this is the first one that has given me this
problem.
Any help would be good!
Regards
Waylander
could be the the settings you used? try encoding through tmpgenc, there you can preview what the output video will look like.
Bizarre vertical lines
By Asterra in forum Capturing and VCRReplies: 55Last Post: 17th Apr 2011, 22:46 -
Bizarre sync issue
By cinesimon in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2011, 17:44 -
Bizarre Happenings
By Mitchum22 in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2008, 10:36 -
Bizarre Pan. ES20 Issue
By bhartmann10 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 3rd Aug 2007, 15:12 -
Bizarre attempt to buy DvdFab
By VegasBud in forum ComputerReplies: 1Last Post: 8th Jul 2007, 21:54
