I am experiencing problems ripping the movie "Duets". I am using CladDVD XP the same way I have used it for the last 50 rips. When I view the movie in Tmpg (in the deinterlace window for example) the video is choppy in many areas. Yes, I tried changing the field order from A to B but still no luck. The DVD is also in good condition. I tried a test encode, and as I feared the choppyness showed up in the .mpg. I this some special movie which requires other settings or filters in Tmpg? Any help would be much appreciated. If you need more info on the process just ask. Like I said, I did this the same way I have done many before!
