I have 2 questions.
1- How do I frameserve directly from Adobe Premiere to TMPGEnc? The site that the link directs me to in the "Convert" section of this site doesn't work.
2- How do I extract the audio only from Adobe Premiere? It will only let me save the audio file as an AVI file.
1) check here: http://www.videotools.net/
2) how about: Select File->Export Timeline->Audio
(I'm not positive that's the way--I haven't really used premier)what are you askin' me for...
I'm an idiot! -
fantomlord,
When I try Select File, Export Timeline, Audio in Premiere, my only option is to save the audio as an AVI file. I want to be able to save the audio as a WAV or PCM file. Do I need to have some plug-in for Premiere to enable me to do this?
thanks -
i am able to export to a wav directly from premiare. i have no plugins installed to do this
what version are you running
as for the exort to tpmg, check out anisynth great little bit of software. and once configured really easy to use
SteveLLAP-Goch... the secret Welsh ART of SELFDEFENCE that requires no INTELLIGENCE, STRENGTH or PHYSICAL courage
---Monty Pythons Flying Circus -
In premeire 6 & 6.5:
Open the avi or other movie source in Premeire (not in a timeline or project-just open the file itself).
make sure the movie's window is highlighted then...
select File --> export movie --> audio then select Microsoft wav.
done. -
this link works fine
http://www.videotools.net/guides/guide_premiere_tmpgenc.php
DVD conversion questions
By Stickboy42 in forum Video ConversionReplies: 3Last Post: 11th Dec 2011, 00:10 -
Photoshop 7 Batch Conversion Questions..
By greenstrat in forum Video ConversionReplies: 2Last Post: 12th May 2011, 11:22 -
HD ts conversion... a few questions
By vol_freak in forum Video ConversionReplies: 0Last Post: 23rd Mar 2009, 12:02 -
Video conversion questions
By Peter88 in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2008, 04:38 -
2 conversion questions
By rendez2k in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Jun 2007, 05:35
