Hi!
I author menus in VCD using Ulead DVD Workshop 1.3, does anyone know how to add files in DVD Workshop when making a disc?
Thanks!
Originally Posted by Dodzzz
In the Menu (1) section, select the button (2) tab. Open your library list (3) and select "Object - General," then "Library Manager." Create a new library (folder) for your project, then import images into your new library by either right-clicking on the (initially empty) list and selecting "Import," or by left-clicking the open folder icon (next to 3).
Suggestion: use Targa (.TGA) images instead of JPEG images. They are very high quality, and 32-bit Targas have alpha transparency (i.e. pixels can be made 0% to 100% invisible).Milo D. Cooper
http://www.miloonline.net/ -
sorry MiloDC, but it didn't help..
what I want is that I could add backups of my high resolution stills (in .jpg or anything else) inside one of the VCD folders created by DVDWS. (like in Nero, you can drag & drop additional files to one of those vcd folders)
Making video into timelapse, but adding frames
By oggologgo in forum EditingReplies: 7Last Post: 30th Dec 2010, 11:26 -
Adding extra folders or files to BD Disc
By jntaylor63 in forum Authoring (Blu-ray)Replies: 2Last Post: 2nd Feb 2010, 13:48 -
Adding Bmp/Jpg to Flav
By Soixante in forum EditingReplies: 0Last Post: 11th Jan 2010, 14:54 -
Making an avi from jpg, bmp or png files
By cabs46 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2009, 06:14 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03
