Hi!
My Problem is that when I try to convert a VCD out of a Divx AVI (size 690MB), It finds the Video out of AVI but not the Sound... I read on a site that sometimes i need to split the sound and video from a file then and convert the sound to PCM Wav then add it back... but how, as it can't find the sound at all? all it says is that it's a illegal MPEG... odd! can anyone please help me?
I do have another problem.. I tried to multiplex a MPEG2 to MPEG1 (VCD Header trick) but it cuts the movie after just about 100MB's Why??
Is it better if I convert the MPEG2 to VCD normal way?
Btw, I'm using TMPGEnc
Would appreciate help :D
Yours Zoolo!
You can use VirtualDub to rip the audio from the file. Load the avi file and ago to the File Menu and choose 'Save Wav', then re-encode and use the saved wav file as the audio file on the tmpgenc front page
Well it still doesn't seem to work, when I try to encode with panasonic it stops or would not let me to include the new WAV file...
Yours Zoolo!
Problem with audio when converting AVI to MOV
By emmajane in forum Video ConversionReplies: 5Last Post: 6th May 2011, 10:23 -
Problem converting MKV files with a DTS audio track to DivX
By ryebeena in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2009, 04:31 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
