Hello, I was converting some AVI files to MPEG to put on a VCD. In the past, I converted them using (somewhat) low quality. I asked for some higher quality settings in TMPGEnc on another forum and so I used these:
Stream Type: MPEG-1 Video
Aspect Ratio: 4:3 525 line (NTSC)
Frame rate: 29.97 fps
Rate Control Mode: Constant Quality
-Quality: 80
-Max. Bitrate: 3000
-Min. Bitrate: 300
VBV Buffer Size: 112
Motion Search Precision: High quality (slow)
Video Source Type: Non-interlace (progressive)
Field Order: Top Field First (Field A)
Source Aspect Ratio: 1:1 (VGA)
Video Arrange Method: Full Screen (keep aspect ratio)
Stream Type: MPEG-1 Audio Layer II
Sampling Frequency: 44100Hz
Channel Mode: Stereo
Bitrate: 128
You might want to know that the source file has 48000Hz and when I burned them onto VCD using Nero 5, the VCD has sound problems. The audio keeps on breaking up and pausing. I then selected a small video clip for converting in TMPGEnc using a maximum bitrate of 2520. But the audio problems are still there.![]()
I'm not too sure about this because you seem to have created an XVCD (bitrate != 1150), but I think the audio bitrate has to be 224 kbps all the same.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
It could be your field order or that you're creating a XVCD.
Um...actually, I tried lowering the VBV Buffer from 112 back to 40 and it worked! I wonder why is this?
sound problems. GSpot 2,52
By camino camino in forum Video ConversionReplies: 0Last Post: 13th Jul 2010, 05:44 -
Problems with sound on 6ch
By pixiesoft in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Apr 2010, 07:12 -
Sound problems
By maltipom in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 13:37 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 14:43 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 06:36
