I'm having this problem while using this guide.............................
http://www.vcdhelp.com/sync.htm.
When I use Goldwave I get this message after I open my mp2 file.
"Cannot dtermine format of file:
Please specify a format below"
My choices are PCM, Telephony, Floating Point, Text.
I've tried it a few times with no luck.
Thanks and I'm real new at all this!
I had the same prob, the movie is moving, but the words aren't in sync with the people right?
You need to download Virtual Dub, go to a search engine and type it in the key word field, its not hard to find and its freeware.
This tool will check your file for "bad" frames. Then you can remove the bad frames and re-save the flick.
This worked for me, and it was easy to use. ANy ?'s ...just hit me back.
-Good Luck
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
Video and Audio out of Sync
By Filmmakerx7 in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2012, 06:44 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Video Audio sync help
By carasy in forum Newbie / General discussionsReplies: 10Last Post: 19th Nov 2009, 20:09
