I, like others who have posted in this forum, am looking for a DVD player that can read both NTSC and PAL. I've seen some players listed, such as a couple by Cyber Home. My question is this: Can I switch back and forth between the two formats for an unlimited number of times? I've heard that players will let you switch formats 4 or 5 times, and then it will stick with the last format, and won't let you change again. Does anyone know if Cyber Home players will let you keep changing?
Melissa
Are talking about DVD-players that can play NTSC or PAL disks. Or you are looking for player that can play Region 1 or 2 disks ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
You are confusing NTSC-PAL with region coding, and the switching is for region codes. This switching of region codes is a function of PC DVD players not standalone DVD players. If a DVD player states that it can play PAL and NTSC formats then it can play them full stop, there is no time limit. It does not necessarily follow however that it will play all region discs, so make sure that the player has this option if you are planning on playing discs from another region.
To illustrate, lets say you have a DVD player that can play both PAL and NTSC discs.
You are in region1 (USA) NTSC
You buy a region2 (Europe) PAL DVD
Although your player can play the PAL format, if it is locked to region 1 it will not play the region2 PAL disc.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Do They Exist? Blu-ray players that supports NTSC, PAL
By xobituaryx in forum DVD & Blu-ray PlayersReplies: 21Last Post: 26th Feb 2010, 16:03 -
Ntsc BluRay players play PAL(region-free) dvdr?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Nov 2009, 19:48 -
Portable Dvd Players...PAL/NTSC Friendly?
By Moontrash in forum DVD & Blu-ray PlayersReplies: 3Last Post: 25th Dec 2008, 19:41 -
Format free DVD-R (plays in both PAL and NTSC DVD players)
By Disco Makberto in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2007, 01:34
