Does anybody know how to create DVD-text, similar to CD-Text. It displays on a few DVD players like the Sony DVP-705. The only disk i have found that supports it is Not Another Teen Movie, Region 2. It would be pretty cool to have movie names appear... Found nothing in ENGLISH on the web...please help. Taverymuch.
you can do it in Maestro:
Generally, the names you assign to DVD Movies (by renaming DVD Movie icons in the Project Manager, as described in Chapter 6) are for your use only.
By checking this box, names that you assign DVD Movies will appear as Title names on those DVD players that offer the feature.
However, if you select the option EMBED PROJECT TEXT DATA IN DVD IMAGE in the General tab of the Project Properties dialog, then the names you assign DVD Movies will also appear as Title names on DVD players that are equipped to support the Text Display extensions of the DVD-Video Specification (version 1.1). Of course, if you choose this option, be sure to take extra care in spelling and phrasing each DVD Movie’s name.
Note: By checking this box, some set-top players will display the name of your movie menu and chapters on the LED display on the front of the player. Others, such as software DVD players, will display the information in the application itself.
Copyright © 2000 Spruce Technologies, Inc -
which means most likly also that you can do it with ifo edit ... i don't know how though - you would have to compare 2 ifo perhaps ..
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
HELP! Too Much Text - I Need Labelling Template For Text
By kasius in forum MediaReplies: 5Last Post: 6th Dec 2008, 16:08 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 05:14 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
