Im trying to extract the audio from an AVI i just downloaded in VirtualDub but when i load the file i get an error saying "Improper VBR audio encoding..." Is there any way I can fix this or use another program that will extract the audio so i can use it later when i encode the film into mpg format with TMPGEnc?
Mike
Results 1 to 16 of 16
MikeWeb
http://mikeweb.atnet.ca -
This post ought to help ya.
http://www.vcdhelp.com/forum/viewtopic.php?t=126632&start=0&postdays=0&postorder=asc&h...riable%20sound -
Thanks for the link. I tried what it said but when i try and save the WAV file i get this error.
"The requested audio compression is not capatible with the input format. Check that the sampling rate and the channel count of the input match those of the requested format."
Any idea?MikeWeb
It more than likely has AC3 audio
http://www.vcdhelp.com/forum/userguides/91588.php -
sorry my english
I use VirtualDub and extract the audio (AC3) in to a file...
After, i use AC3Tool, and convert to PCM (about a 1GB file result)...
When AC3Tool can't deal with the file, i use Wimamp, using Disk Write, and he can deal with the conversion (it's a trick i think
Now, in virtualDub, i use the DIVX ou XIVD and for audio, the Wav i create, and Framserving to TMPGEnc...
I use also the Subtitle filter, in VirtualDub...
And everything works great... TMPGEnc, can deal with the job...
When i discovered AC3Tool, i'm happy, but after, a lot of movies give me errors in AC3Tool, but i have a good ideia, and think in wimamp... Great... -
Hmm.. this is weird, I tried it again on my laptop instead of my desktop and I dont get an error when saving. Anyone know what could be the problem?
MikeWeb
Click on file information, what does it say for channels and audio compression ?
Channels : 2 (Stereo)
Compression: Unknown (tag 0055)
MikeWeb
Looks like it has ac3 audio, try following the guide I posted above and see how you get on
Well I encoded the movie without using the ac3 audio link you gave.
I did it the way I always have using full processing mode in VirtualDub and encoding with TMPGEnc. The end mpg seems to be fine, the audio and video are in sync.
Should I redue the audio using the steps in th ac3 audio link you gave me? What is ac3 audio anyways?MikeWeb
If its in sync then there is no need to mess around with it. AC3 is another term for dolby digital.
http://www.afterdawn.com/glossary/terms/dolby_digital.cfm -
I forgot to ask but is AC3 that much better? I only have a Pro Logic amp.
MikeWeb
AC3 or dolby digital is 5.1 channels, front left, front right, centre, rear left, rear right, and sub. Pro logic is just 4 channels, front left, front right, centre and rear. So yes DD or AC3 is better than pro logic.
Hmm.. maybe I should redue it then, do you think I would notice a diffrence since I only have a Pro Logic amp?
MikeWeb
Sorry what I posted before was a bit misleading, ac3 or DD is typically 5.1 channels. Bit in your case it was 2 channels. You can have 2 channel DD
Need help with virtualdub error involving VBR encoding
By Hark in forum EditingReplies: 16Last Post: 11th Feb 2010, 23:45 -
Virtualdub has detected an improper VBR audio encoding
By lingoguysw5 in forum AudioReplies: 17Last Post: 26th Oct 2009, 10:12 -
Error While Encoding Audio On VirtualDub
By ashwin.terminator in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2009, 09:00 -
VirtualDub 1.8.6 = Error about Audio (VBR) ??
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 28th Oct 2008, 10:55 -
virtualdub has detected an imrpoper vbr encoding...The current preference..
By von_25 in forum Newbie / General discussionsReplies: 11Last Post: 25th Mar 2008, 01:57
