I download a avi both halfs have no sound but the video is fine. Used Vdub and got the info on the file and it says it is compression unknown (tag 2000) what does this mean and how if at all do I get the sound to work? thank you Marty
mee
It means the audio track is using AC3, you can just go ahead and convert it with TMPGEnc if there are no junk frames, or you can save out the audio using streaming then convert it later.Originally Posted by mee
This will help
http://www.vcdhelp.com/forum/viewtopic.php?t=137413 -
thank you both for your feed back ... it is great to get such fast responses with such easy to follow instructions to answer your questions and to fix any problems ..... it is great to have such a good forum!
mee
mp4tools/mencoder - compressed with an unknown/unsupported compression
By furrytoes in forum MacReplies: 4Last Post: 3rd Sep 2011, 09:48 -
MPEG4 subtitles
By miconba in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2011, 01:11 -
General query about an unknown TV
By Seeker47 in forum DVB / IPTVReplies: 13Last Post: 13th Aug 2009, 14:16 -
Sorenson Squeeze compression causes sound to be not in sync with video
By psaad in forum Video Streaming DownloadingReplies: 8Last Post: 23rd May 2008, 15:53 -
unknown file
By nicgrosso in forum ffmpegX general discussionReplies: 27Last Post: 7th Apr 2008, 15:20
