I am trying to encode with TMPGenc but keep getting "index of scan line is out of range (240). I don't know what this means or how to correct it.
Hope someone can help.
check the AVI for junk frames.
http://www.vcdhelp.com/forum/userguides/135552.php -
Thanks. Have checked for bad frames and none were reported. What else can I do.
Did you use Vdub MP3 or the normal Vdub...
TMPGEnc
Option > Environmental settings > VFAPI plug-in > DirectShow MM File reader
Right click and select higher priority, do that several times until its at the top with a value of 4
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
