i have a 780mb mpeg that i'm trying to burn using nero. but when i get to the burn page, it gives me a "not enough space on media" message.
I've read that you can fit 800mb of video on 80min CD.
What am i doing wrong??? i have nero 5.5
Thanx
You are trying to burn the mpeg as (S)vcd using the wizard, right? Because if not and you are just trying to burn the Mpeg straight it will give you that error.
read this post - might be your problem
http://www.vcdhelp.com/forum/viewtopic.php?t=137249 -
To over burn in Nero you need to go to preferences and click on the Expert Features tab. Click on the second box. Type in 82:00 for the maximum amount of minutes that you want Nero to burn for you. You might want to check you CD Burner and see if it supports overburning or else you will probably get an error at the end of disc and your disk probably won't be "finalized".
Hope That Helps!!! :P
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
LG GH22LP20 16X won't burn at more than 2X
By BeyondInvisible in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Feb 2009, 14:55 -
PGCEdit won't burn DVD
By Weapon-X in forum Authoring (DVD)Replies: 9Last Post: 27th May 2008, 07:18 -
Nero won't burn video DVD
By solo_voyager in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 22:06 -
DVD Won't Burn
By wwpranma in forum Video ConversionReplies: 2Last Post: 25th Jun 2007, 04:32
