Does anyone know if the Eclipse 695 is miniDVD compatible , i have created a miniDVD with Ulead MediaStudio Pro + DVD plugin , however the player refuses the play with a 'wrong format' message.Also is there a format to which a mp3 cd must be set. I put in a cdrw with a few mp3 files and the player (again) refused to play.
Thanks in advance for any help
well its not on the list..not that the list is up to date, because pplayer that is capable is not on the list..but if it didnt play...I will assume it doesnt play miniDVDs
Eclipse ripping problem
By cyflyer in forum DVD RippingReplies: 3Last Post: 29th Nov 2010, 06:35 -
Convert DVD9 layer break to decimal format on Eclipse report?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2010, 18:41 -
July 22, 2009 the longest solar eclipse of the 21st century
By freebird73717 in forum Off topicReplies: 3Last Post: 23rd Jul 2009, 09:39 -
deinterlace miniDVD and miniDV material before (re)encoding to DVD or not?
By Massa in forum Video ConversionReplies: 3Last Post: 2nd Jan 2009, 13:54 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 13:48
