I really am confused about what media to get. I don't really trust the 50 cent no name dvd-rs out there. There are alot of companies that sell dvd-rs. So if someone who has the Sony DRUA500 that bought media online can tell me if that media is reliable for making backups of your collection of dvds, i would really be thankful. Please if you can include where on the web you got it. Thanks Alot :P
Here is what worked for me...
SONY DRU-500A Detail media report
It is with details as you can seeSame posts are also at www.sonydru500a.com but one per post.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
i have used princo 1x, and the accu 1x media. both work great, and they are less than a buck a piece. burned a 150 so far and the only errors were my fault. i found them to be more compatible then memorex. (all -r)
try
allmediaoutlet.com
meritline.com -
Donpredro's link is good.
For DVD backups, I order Accu from cdrdvdrmedia.com with cases for a little over a $1 each. Bad thing is that with Accu, the manufacturer always varies, and some people haven't had much luck, while others can burn at 2x! If you're lucky, you will get some good ones.
For your home made edited and authored disks, I recommend using some main brand quality for best compatibility. After spending hours at editing and authoring, it doesn't make sense to skimp to save a dollar.
I've never had coaster. It's good to use RW when experimenting/testing. -
Originally Posted by JasonKPinnacle Studio 8 and DV home video editing (ver.9 already home)
hi,
I always Burn on a RW media and test it and then burn on DVD-R. For my home movies i use TDK. I got a Good Deal for 16 Discs TDK for 1$ each from compusa and 9.99 for four DVD+RW for Verbatim. i use the RW for testing and so. I have not tested any of the cheap stuff. but will soon. No costers so for on tdk or Verbatim. But once coster on memorek. i got only one disk for 2 $. and did not work out.
My M/C config
P4 1.3 / 512 Rdram
Sony Dru500a
nero latest version.
ulead moviefactory
Media studio pro for editing
Ellion HMR 500 Media Recorder
By lyn.greenwood in forum Newbie / General discussionsReplies: 1Last Post: 8th Aug 2011, 07:21 -
Backing Up media files
By AndreL in forum MediaReplies: 1Last Post: 11th May 2011, 03:54 -
Backing up video tapes with windows media center
By macmaster in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2009, 16:19 -
What is the best method for backing up a DVD to DVD+R DL Media?
By xoADAMox in forum Newbie / General discussionsReplies: 8Last Post: 28th May 2009, 04:36 -
VC 500
By jlh050965 in forum Capturing and VCRReplies: 1Last Post: 24th Sep 2008, 10:00
