Are audio and video streams in mpeg2 files synced purely because they're the same length, they have some king of flagging sustem that matches points between the two or something else? Do other formats (mpeg, avi, vcd, divx etc.) do this the same way or differently and from one another? If it's purely a length of file method, it seems very precarious at best leaving me with little confidence that files demuxed with one program and remuxed with another can be in sync though I see this suggested all over which one would hope means it does work. Purely an "understanding" type of question. Have nothing specific to complain about.
Tiribulus![]()
Audio, just like the video, works with frames
If you have a PAL movie, witch has 25 fps, every second has 25 images. For every frame you have 1 audio frame too, witch is 1/25 second...Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Does this hold true for ntsc as well, in general, I know the framerates different? Also does it have a way to match the audio and video frames with each other or are they just stuck together and we hope that they correspond?
Thanks BTW,
Tiribulus
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
audio out of sync with video
By natty in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2008, 06:21 -
video and audio out of sync
By saleen in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2007, 13:15
