Which version of it is best?
I have the original Virtual Dub,Nandub and Virtual Dub-mp3 freeze.
The main branch of VirtualDub is the best by virtue of the fact that it is the only version that is actively developed.
Development of Nandub (Nando's version, there are others) stopped in July 2001 and is unlikely to return as it simply allowed tweaking of codec parameters that in the end didn't really achieve an awful lot. It also does not work with the newer DivX codecs, only the old 3.11 alpha release. For a more thorough treatment, look here.
The other version you mention can be useful but is also unsupported. It allows you to add a Variable Bitrate MP3 soundtrack to your videos which means you can encode the audio with a decent program (namely LAME), the antifreeze portion is no longer necessary and was a patch for the old DivX codec as well. -
deleted my answer , as someone above answered with a good set of points
See if this helpsOriginally Posted by crack_man
http://www.vcdhelp.com/forum/userguides/135552.php
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 04:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 07:00
