When I didn't have a Pioneer 105 DVD-R I was capturing my tv programs and burning them to SVCD. Now that I have a burner I want to move these SVCD's to DVD-R. I realize you can't author a SVCD directly to DVD-R.
Here's where I get hung up. I am using tmpgenc to join the 4 mpg2 files that I have extracted from the SVCD's. I join parts 1 and 2. The audio is fine throughout the portion that contains part 1 but as soon as part 2 starts playing the audio sync gets WAY off...I don't know why and I am getting frustrated. Instead of having 4 cd's i really want to put this crap on one DVD-R. Can you help me out?
You don't have to join them if you use a good dvd authoring tool that can make them all play continues after each other. I just tried ulead moviefactory 2 and it will automatically play each mpg clip after each other. I updated the dvd-svcd guide, www.vcdhelp.com/svcddvdr
Other authoring tools supports this also, like dvdit, dvdmaestro. You then select manually next play item.
But if you want to join to remove the svcd overlapping(repeating video between svcds) this would not help you.
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32
