Anyone know where to get the ac 3 codec, without installing the whole nimo codec pack?
Results 1 to 9 of 9
i onced looked at doom for it and i couldn't see it.
but heres a direct link(copy and paste without the space)
http:// download.divxmovies.com/ac3codec.zip -
Originally Posted by kaae2000
http://www.vcdhelp.com/forum/viewtopic.php?t=137413
See end of guide for programs to download -
Originally Posted by dphirschler
If you install a software DVD player (WinDVD, power DVD) I believe that will install an AC3 codec. Of course, you may be a VCD only person . . . .
Now I have found the ac3 codec and install it (why do I loose it everytime I install xvid codec?) so far so good. But I have a movie K 19 and the audio format is still unknown by Virtuel dub and G-spot tell`s me that I need a update for my audio codec???? Where can I find this update?
Load it into Vdub select File > File Information
What does it say you have for Video and audio ?
Vdub will say unknown on an AC3 audio, so don't worry about that..
see this
http://www.vcdhelp.com/forum/userguides/137413.php
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 14:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
which codec
By peterg60 in forum Video ConversionReplies: 6Last Post: 25th Jul 2007, 15:52
