Ive been making vcds for quite some time now and until i got my dvd writer ive had no problems. I read these pages religiously every week and i know that this question has come up a thousand times so for all you poor people who answer this problem week in and week out, hats off to you. Anyway im tring to eventually put an avi file on dvd which i know i need to encode first but when i try and load up the avi file it says "FILE UNSUPPORTED". I have quite a few codecs and have fiddled with the enviromental setting and still no joy. Anyone who can explain what i have to do to get it working is tuly a great being.
Cheers for reading this!!!
p.s help!
Do you have Nimo Pack?
If you havenīt then I suggest that you download it. -
i've read your post
had the same problem
try this: check your video codec -> if the avi is divx 5.0 encoded, tmpgenc cannot read this, you have to encode the avi in something else (i encode it in mpeg-4 with virtual dub) then it shoul work
hope this will help you out -
Originally Posted by Cybelia
First make sure all codecs are installed. If it still doesnt work change the directshow reader priority in the environmental settings of tmpgenc. Try having your setting similar to this
DirectShow Multimedia File Reader.......3
AVI2(OpenDML) File Reader................1
AVI VFW compatibility Reader.............0
CyberLink MPEG-2 Decoder.................0
Microsoft MPEG-1 Decoder.................0
Wave File Reader..............................0
BMP/PPM/TGA/JPG File Reader...........-2
DVD2AVI Project File Reader 1.76+.....-2
TMPGEnc Project File Reader 2.58......-2 -
Originally Posted by adied
Test your system see if you have anything missing
http://www.vcdhelp.com/forum/userguides/135217.php
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
TPMGEnc DVD Author 3.0.9.166 crashes on writing to disc
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 03:40 -
TPMGEnc DVD Author 3 Menu Problem
By ^D3vIL^ in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 17:43 -
AVI comes upsidedown using TPMGenc 4.0 XPress for editing
By rominho in forum Newbie / General discussionsReplies: 4Last Post: 17th Jun 2007, 19:38 -
By rominho in forum EditingReplies: 0Last Post: 14th Jun 2007, 09:09
