I've noticed that when playing a XVCD on the standalone DVD player, a highpitched(digital sound) beep will blend in with the audio. It's like a pop while playing an LP. It's not there when played on the computer CD-ROM though. I have tried recording at different speeds. I am thinking that it may be my CDRW burner. Here is my setup:
ATI AIW 128pro
Philips CDRW804
Memorex CR-Rs
AMD 800Mhz processor
Win98ME
Ulead
NERO 5.5
It might just be that your DVD standalone's processor isn't maximized to play XVCDs at that bitrate. I've burned a couple of movies with some experimental bit rates, and I've had popping and pauses in the video similar to watching a movie on a computer with low memory. You can either A) try experimenting with XSVCD, which is more flexible and forgiving, B) watch those bit rates (audio AND video), or C) try upgrading the firmware in your DVD player (possibly available from your manufacturer).
I have been testing the XVCDs that I have made on several DVD players. The highest I go is 1150Kbps with video data rate which is a standard for VCDs. This could be a factor in any one of the following things that I am doing or using: My CDRW burner(Philips), My CDRs(Memorex), The burning rate (although I have tried x2 with the same results), the file being noncompliant(but I have heard people say that Pioneers and Apex DVD players play noncompliant XVCDs without a problem. I will be glad when I've got this problem solved and I will be able to pass the advice on to others on what to do to make playable XVCDs.
"watch those bit rates (audio AND video)"
What is an ideal video bit rate,higher than 1150Kbps, without slowing things down...on most DVD players? The XVCD I made with ULEAD was 2300Kbps(video)/44100Kbps-224(audio)/13(performance level)
It seems as though only JVC and Apex DVD players could even handle this disc (the audio still had beeps in it though, but atleast the video wasn't dragging).
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
Hmmm....That's New - Down arrow key....my computer beeps
By hech54 in forum ComputerReplies: 4Last Post: 26th Jul 2009, 02:06 -
Overlaying/generating beeps & pauses during video
By jmelvin in forum EditingReplies: 5Last Post: 27th Feb 2008, 01:29 -
PC beeps when comes up
By mol3000 in forum ComputerReplies: 2Last Post: 21st Oct 2007, 17:21
