Tried:
From graphedit using avimux and filewriter -> bad framerate and VirtualDub gives an "Codec missing.." errormessage when opening the newly converted .avi.
ASFTools. The converted filesize is larger than the original and does not playback video, only audio.
I'v heard that the new WM9 codec refuces to play video out of the avi container and will only accept data coming from wmv, is this true? If so, we would need a 'modified' wmv9 decoder to be used with the ASFTools converted avi.
The idea is to backup a DVD using WMV9 videocodec and AC3 audio, and to my knowledge muxing AC3 with wmv is not possible since all muxers that I know of (all one of them, NanDub) that can handle AC3 can't handle wmv/asf.
Any advice is appriciated.
did u try and see if it'll play in Windows media player (mplayer2)?
You may need the VCM codec, here
Freeware to encode to WMV (w-WMA audio) video?
By Diana (Cda) in forum Video ConversionReplies: 6Last Post: 6th Jan 2012, 11:19 -
Can't encode WMV to MOV
By scratface in forum ffmpegX general discussionReplies: 3Last Post: 21st Feb 2009, 12:24 -
DV Capture to WMV encode. Looking for some advice.
By silmarallion in forum Newbie / General discussionsReplies: 10Last Post: 19th Aug 2008, 17:02 -
Best way to re-encode 13GB DV file to 4.5GB avi/mpeg/wmv
By ColKurtz in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2007, 21:59 -
ffmpegX VC-1/WM9 support
By Thargok in forum ffmpegX general discussionReplies: 2Last Post: 21st May 2007, 12:03
