I have a panasonic A160 player. I bought this back in 1998 but have had never had a single problem. I tried playing a VCD which I had made but it came up cannot play. That caused me no problem as I have one which can play it in the front room. The only problem is that now whatever disk I put in the player be it region 1 or 2 (the player is chipped) it says that it cannot play it, I have looked through the menus and everything is normal and it is not the laser as it plays audio cd's.
Thanks for taking the time to read and I hope that you can help.
You can't compare Audio CD's with DVD's, they're totally different specs.
Maybe your laser is slightly out of focus or worn out?
DVD/R discs need a 650nm laser, while for CD's it has to be 780nm.
I think it could be the laser, since it needs to be more accurate to read DVD's instead of a CD.
MrSnake
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 21:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 21:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 13:37
