When I use PowerDVD to play a DVD on my P3 400MHz computer, the CPU Time is 100%! and the picture are not smooth ...
But if I use ASUSDVD, the CPU time is about 70% and the picture is smooth ..
What's the problem ?
What setting on PowerDVD should I change ?
Thanks!
Results 1 to 9 of 9
I'm under the impression that ASUSDVD is PowerDVD in disguise?
/Mats -
Seems a little high... Make Sure DMA is enable on your DVD drive.
-=| Felix | =- -
Thanks for the replies ...
I've enabled the DMA.
The problem is why it's OK on ASUSDVD (not a well-known software) but it's not OK on PowerDVD ?
It must be software setting problem, not hardware problem ... -
What video card are you using. If it's an onboard solution and it's an Asus motherboard then the AsusDVD you have was optimized for your motherboards onboard solution most likely reducing it's CPU overhead, I can play DVD's on my machine (xp2100 Gf4ti4600) with software Dolby digital or DTS decoding at about 10-20% cpu use but my video card helps the DVD playback quite a bit.
We will either find a way or make one - Hannibal -
thats a very smalll system huh? you may want to try to
defrag you system files as well, dont know what OS u
are using, but xp cant do it, you need diskeeper to do
that, and it only works on NT... -
Just thought I'd also mention, direct from PowerDVD's website... IF you are decoding a dolby digital stream down to 2 channel audio... You are really pushing the minimums for the program in the first place, so yeah, 100% actually doesn't sound too unusual.
- *Windows XP, 2000, ME, 98, 98SE, 95, OSR2 or Windows NT4.0 SP5+
*Intel Pentium II 350MHz* or above, or any Athlon processor
*DVD-ROM, DVD-R/RW, DVD-RAM, or DVD+RW drive with 1394, ATAPI, SCSI, USB 2.0, or Card Bus interface
*PCI sound card, USB audio box or motherboard built-in audio device
*64MB RAM
*Hard disk requirement of at least 40MB
*Display card supporting DirectDraw overlay
*Optimal Screen Resolution 800 * 600 min., 1024 * 768 recommended
We will either find a way or make one - Hannibal - *Windows XP, 2000, ME, 98, 98SE, 95, OSR2 or Windows NT4.0 SP5+
CPU Temp Erratic and High in BIOS?
By bevills1 in forum ComputerReplies: 3Last Post: 7th Jul 2011, 12:09 -
CPU Fan is on high all the time
By alegator in forum ComputerReplies: 16Last Post: 26th Dec 2009, 23:23 -
Extremely low burn speeds, High CPU usage
By BetaMaster in forum Authoring (DVD)Replies: 13Last Post: 20th Nov 2008, 13:23 -
H264 High CPU % on Dual Core and 9600GT
By redshone in forum Newbie / General discussionsReplies: 9Last Post: 16th Oct 2008, 08:35 -
Question about Windows error msg and high cpu when right clicking on avi
By jimdagys in forum ComputerReplies: 3Last Post: 4th May 2008, 18:01
