Hi
I downloaded a free trail from Ulead called DVDMoviefactory2. When I started the installation it immediately stopped and say "please insert disk 1 with the file layout.bin.
I tried to email Ulead but they didn't answer me.
Hope someone knows where I could get this layout. bin file for this program or how I could solve the problem.
I also tried some of the layout.bin files who are on my computer but no one matches.
~Sezin
dont know what OS your using but if its win2k or XP , start the installation and if it hangs , look in your temp dir in a sub folder and all the files should be there instead .. you can even install ussually from there..
though first i would perhaps download the demo again -
The bin file you need is in the directory where you unzipped the download to. Just use the brouse feature to tell the installer to look in that folder for the bin file.
If it works, don't mess with it, don't tinker with it and don't break it.
Just wanted to say hello...
By Novice2010 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2010, 12:20 -
Are my installations/registry settings confusing my 5.1 setup?
By takearushfan in forum AudioReplies: 0Last Post: 2nd Jun 2010, 15:47 -
XP Installations. Big problems.
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 9th Mar 2010, 10:43 -
I just wanted to thank VIDEOHELP.COM :)
By MISS CHIEVOUS in forum FeedbackReplies: 3Last Post: 18th Sep 2009, 03:29 -
Just wanted to say thanks!
By freebird73717 in forum FeedbackReplies: 0Last Post: 30th May 2008, 17:10
