hey i was wondering if it is possible to take completely standard VCD mpgs and put them on a DVD-R somehow without losing quality or reencoding? They are 23.976 fps so im not sure how that works anyways if it is give me a link to a guide or something otherwise im up for suggestions on another approach.
23.976 is not really standard. Most DVD Players will play them, but I thought I would clear that up. BTW Standerd is 29.976. Again btw, these are NTSC standards. If only the whole world would go PAL (25fps). To bad I live in an NTSC country.
it is standard for vcd is it not? and i have heard you can put vcd files on a dvd but since it is film instead of ntsc will it not work?
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 02:25 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 01:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
