  1. Hi to whoever reads this post,
    I just have a question on how to effectively remux, in my case, a CCE encoded file back into the VOB set of the DVD. I tried by using IfoEdit 0.95 with the VOB Extras option and it seems to work well.
    But when I open it up in PowerDVD and WinDVD, the first chapter seems to work fine, but when I watch the others stuttering occurs or it just pauses and doesn't play on.
    Any help will be appreciated, btw, the DVD I'm doing is MIB2. I want to presevere everything on the DVD so I only compressed the main movie video.
  2. did you do an ifoupdate cause you encoded the main vobs ?
    thingimijig.
  3. Would that seem necessary?
    Cause even playing the newly created vobs in PowerDVD or WinDVD searching or going to a set point in the file would cause stuttering or speed up and audio out of synch.
    I would really love for a solution. Would it have to do with the CCE setting of Close GOPS and Restrict the Auto I-Frames stuff, cause I did not have those two options ticked. Also the N/M or whatever was set to 3 and 4 respectively.
  4. Just in addition...
    The stuttering and speed up seems just to happen after about 6 mins into the movie, or the beginning of Chapter 2.
    I have not tried running the file, though, from start to end to see if the audio sync is a problem and stuttering arises. I think it only occurs when u advance by chapters and manual searching.
    This is really annoying! I really want a working file so I can burn it!
  5. why dont you try ifoupdate cause it realigns all the chapters.
    maybe that is the problem as it only starts happening as you hit chapter 2.
    thingimijig.
  6. Doesn't seem to work.
    Still the same result.
