I write my DVD's with recordnow and after it rights it verifys the data. i dont want to experiment because the disks are too expensive. does anyone know if the DVD will work just as fine without verifying the data?
True Story
The porpose of data verification is to make sure everything that you wanted to copy to the disc actually made it to the disc as it was supposed to. If there was a spec of dust on the disc during the burn process, the burner does not know and doesn't care, so if you don't verify you won't know about it until you try to play that area of the disc.
Disc verification
By johnss0n in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Mar 2011, 16:12 -
TS File Verification
By maglev_tgv in forum DVB / IPTVReplies: 4Last Post: 1st Feb 2011, 07:28 -
Do you despise those online verification codes?
By yoda313 in forum ComputerReplies: 13Last Post: 15th Oct 2008, 18:18 -
dvd verification
By blas in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2007, 09:16 -
Nero 7 data verification failed....?
By LoneWolf1038 in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 09:06
