"My mpeg this" "My Mpeg that" or "How do you convert an Mpeg"
Please use the term a bit more descriptively, as there is more than 1 type of "MPEG"
MPEG-1: A video standard Normally used with VCD
MPEG Audio Layer-3 (MP3),audio compression
MPEG Audio Layer-1 and MPEG Audio Layer-2 are the previous versions of MP3.
MPEG-2: This video standard used on DVD and SVCD
MPEG-4: New version of the previous MPEG standards, normaly an AVI/ASF
How can I convert an Mpeg to Mpeg![]()
How can I convert an Mpeg 4 to Mpeg 1![]()
You're sounding misleading here, KJ. Newbies can get confused between MPEG-3 (another mpeg A/V spec) and MPEG-1 Layer3 (MP3 audio). They're different and the official MPEG3 spec was never used.
"A proposed variant of the MPEG video and audio compression algorithm and file format. MPEG-3 was intended as an extension of MPEG-2 to cater for HDTV but was eventually merged into MPEG-2."
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40
sorry your confused
