I downloaded a movie SVCD and when i just try and burn the .bin/.cue w/ overburn on it wont play in my DVD player
Ive extracted the .mpeg from the .bin and now i need to know what to do to get it on a CD that i can watch it on my DVD player with (yes i know my DVD players plays VCD's cause ive made them before) but this one has me stumped
ive read things about, tricking header files and reduxing or remuxing or something and i had no idea what that was all about
thx in advance
<edited>
Results 1 to 18 of 18
Originally Posted by slogg
If you want to re-encode to VCD you can load it into TMPGEnc and convert to Mpeg 1, but you need to install a Mpeg 2 filter first like Ligos -
ugh, when i try to open the .mpg file it says "unable to open or unsuported" even tho i just downloaded the ligos thing
ive gone in circles with the FAQ and i end up back here.... how do i make the MPEG2 into an MPEG1 (i think i have like every video converting software around from all the "use this" links i get and then it will say "but to do this u have to use this program" the program that is usually my original problem)
okay oaky
I found some more guides and did the header trick, ive tried the Multiplex and the Merge & Cut option but when i put the CD in my DVD player it is choppy as hell, xcept for the 1st like quarter of a second if i pause and un-pause it, it runs fine (mind u this is for a quarter of a second)
how do i encode it so it isnt choppy, i read something about chaning bitrates and such but what should i change it to (i have a pioneer dv-o5) -
Some players support VCDs but don't support SVCDs. Make sure that your DVD player supports the medium that you are burning. There are some "tricks" that you can do, like the VCD Header Trick. But this doesn't always work. You can do a fourm search on "VCD Header Trick" and follow a guide that way. All it really does is write a MPEG-2, but the header of the file says MPEG-1. You can do this with TMPGEnc with the MPEG Tools in the file menu (i think its the only program that can do this) by demultiplexing (maybe not, I havent read the guides as my DVD Player does support SVCD) and then multiplex and instead of putting the type as "MPEG-2 Super VideoCD (VBR)" Change it to "MPEG-1 Video-CD".
This might be wronge. Read the guides. Hope this helps. -
Convert to MPEG-1 then. Intall PowerDVD (just do a search on it in yahoo) which comes with MPEG-2 decompression. Then you will be able to open the SVCD in TMPGEnc. Then convert with the VCD template for a completly standerd VCD (i try to stick with standerd disks for compatibility reasons).
Originally Posted by DivXExpert
to make the svcd into vcd open the mpg2 file in dvd2avi and save as a project to a folder,make sure you pick an audio track in the dvd2avi settings,its usually track 1,after you do this open tmpg and browse for the project files you just made and load them into tmpg and load in a vcd template after, then encode away
TMPGEnc +
Option > Environmental setting > VFAPI plug-in > Ligos
Right click and select higher priority, do this a few times until its at the top -
If its not being shown, its not installed ? Did you re-start everything after you ran the instalation ?
File:Item13.zip
Length:15787162 Bytes,15417KB
UUHash:=FFhZHc+9tK6QxK9P6shr0JaUigE=
Virtualdub Guides?
By ATLien in forum Video ConversionReplies: 6Last Post: 23rd May 2009, 22:18 -
FAVC guides?
By php111 in forum User guidesReplies: 64Last Post: 25th Aug 2007, 10:53 -
question about one of the guides
By php111 in forum Off topicReplies: 1Last Post: 8th Aug 2007, 10:31 -
Do You Read The Guides Before Asking Questions?
By classfour in forum Newbie / General discussionsReplies: 14Last Post: 14th Jul 2007, 10:58 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
